I removed the old threshold, it turned out that the gutter connecting the threshold to the body had rotted.
I had to remove the lower guide of the sliding door.
I curved a thin stainless steel gutter and replaced the rotten one.
Then I attached the new sill to the body top and bottom with self-tapping screws.
I set the threshold so that it covers the bottom edge of the door from below and protects it from road dirt. This prevents the bottom of the door from corrosion.
When I removed the threshold and the gutter, a picture of body corrosion was revealed. I cut out all the rotten places and installed fresh iron. What was at hand.
On the back side of the opening, I also had to cut and cook, but this did not get into the frame.
Then I welded everything with electric rivets - welding of thin parts through the hole.
