What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby Noctule » Thu Mar 04, 2021 9:46 pm
Fitted the other ARB, it arrived this morning, 5 mins to fit.
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Keef » Fri Mar 05, 2021 6:22 pm
gotgcoalman wrote:Pics of holes please
My son made a start on the van today and took some pics just for you Mr Coalman :D
Looks like it needs the usual; step, inner sill, outer sill, inner wing, outer wing and some patching. :roll:
Keef
Postby gotgcoalman » Fri Mar 05, 2021 8:34 pm
A bit of pudding would sort that
The tyre must have come from where Ned gets his
I've still got the OS arch to do on mine (amongst other bits)
Sent from my Plus E using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Postby gotgcoalman » Sat Mar 06, 2021 4:11 pm
Now then.......
Discovered this beauty
What's the most random thing found inside box section?
A piece of glass bottle and a plastic screw on bottle cap. Oh and some flakey brown unidentified stuffImageImage
gotgcoalman
Postby Adam mk1 » Sat Mar 06, 2021 9:05 pm
If vans could talk it would say thank you for removing my heavy load, can we go for a run now & I can show you how fast I can run
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Postby gotgcoalman » Sat Mar 06, 2021 11:24 pm
Surprised mine hadn't snapped with the corrosion that's crept in since last poking
Why do the holes never appear in the Summer
gotgcoalman
Postby Noctule » Sun Mar 07, 2021 12:38 am
Because in the summer the hole are full...
...of water.
- DRW with 16" rims
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby cherniy_chack » Sun Mar 07, 2021 6:30 pm
gotgcoalman wrote:Now then.......
When I opened the boxes on my son's car, I found in them, in addition to dirt, coins for several euros.
Pieces of copper tubing and copper fittings for connecting such tubing.
My old propeller shaft began to vibrate. It turned out that the spline connection has large gaps. I replaced part of the propeller shaft, the gaps became smaller, vibration too.
The speedometer is broken.
The car is 30 years old.
cherniy_chack
Postby cherniy_chack » Tue Mar 09, 2021 5:36 pm
Today I replaced the front of the propeller shaft with external splines and repaired the speedometer.
A few days ago, I mounted the LED strip in the dashboard with a glue gun and a drop of glue came off and got into the gap between the rotor and the speedometer leash and made it unusable.
I cleaned the rotor and the glue gap and the speedometer is working.
cherniy_chack
Postby Adam mk1 » Fri Mar 12, 2021 2:26 am
I changed oil & filter had a hell of a game getting filter off, a chain remover type things was crap hammer & chissel job but stil wasn't moving & it started to turn the pipes on ack of filter, in the end had to get a mate hold that back with a screw driver while I hit the filter, took over an hour just to get filter off, tryed bashing a screw driver in filter it was dripping everywhere & tearing
Adam mk1
Postby Adam mk1 » Fri Mar 12, 2021 2:28 am
Adam mk1
Postby cherniy_chack » Fri Mar 12, 2021 2:30 pm
This happens often.
At the last oil change, I also could not unscrew the filter, I left the old one.
I had to pierce the filter with a sharp steel rod and unscrew the filter.
A few days ago I wrote about repairing the speedometer and replacing the splined part of the propeller shaft.
Today I rode a little.
The speedometer is working.
I even forgot that my Mk3 has a driveshaft!
cherniy_chack
Postby gotgcoalman » Sat Mar 13, 2021 5:45 pm
Good to hear from you cheriny_chack
Today I have been making pipes.
Life is much easier with the correct toolsImageImage
gotgcoalman
Postby cherniy_chack » Sat Mar 13, 2021 8:02 pm
Back in the fall, on my MK3 in the forest, a posterior thromotic tube burst.
I had to muffle the exit from the master cylinder and so go home.
Then I gave the car to the painter, where it stood for 8-10 weeks.
In Kiev, there are several workshops on the automotive market where any brake pipes are made to order.
I ordered a tube with M10x1 threaded ends, but I was mistaken - one is like this and the other is M12x1.
When I found out, the car market was closed for quarantine, but they changed the tip and after painting the car, I restored the brake on the rear axle to serviceability.
These are the pipe wrenches I have, and I have more "tricky" pipe wrenches - when I was younger, I was a car mechanic.
cherniy_chack
Postby gotgcoalman » Mon Mar 15, 2021 9:03 pm
Today when trying to re install the fuel tank and discovering it was too in wieldly,I was unable the syphon fuel out.
Decided to tip it into container's.
Hmmmmmm this fell out of the filler neck.
Perhaps it's the cause of the slow filling ImageImage
gotgcoalman
