What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby weseeyou » Fri Sep 14, 2018 1:28 pm
Could someone kindly move this post to follow post on page 52 please for continuity cheers
not perfect by any means but should pass a casual inspection. :)
Haven't found a matching Diamond White spray can yet so its a horrible cream colour . I'll make that discussion a separate thread
TPM961 wrote:Went for something a bit different... Purple!
We documented the whole thing on Instagram, for anyone who's interested check out @moose_in_transit Image
Sent from my ONEPLUS A3003 using Tapatalk
nice job !... did you use a primer or just a top coat ?
how easy is it to paint the plastic bumpers ? did that need a special primer ?
weseeyou
Postby TPM961 » Fri Sep 14, 2018 1:36 pm
First thing we did was flat the whole thing down. After spending all of last summer welding it and fitting new panels etc the bodywork was in good condition. Then went over it with white spirit and taped everything off. Paint was Rustoleum Combicolor, which doesn't require a primer or clear. As for the bumpers we etch primed them first, I think the combicolor will stick to plastic bumpers but weren't 100% sure so primed them anyway! The finish isn't bad, but a bit orange peely so at some point we'll flat it back and polish it.
Your door repair looks good! I could never find a diamond white that came close either, van was many shades of white before we painted it! :lol:
1999 transit mk5 2.5di lwb camper conversion
2019 ranger wildtrak
Quantum 2+2 1.0 ecoboost project
TPM961
Postby cherniy_chack » Sun Sep 16, 2018 7:29 pm
Two weeks ago I made a trip to Ukraine to my brother.
The length of the route is just over 720 km.
Half the way the road is very good, half-bad. I traveled at a speed of 100 km / h, half-no more than 80 km / hour.
The fuel consumption there was 6,8 l / 100 km, back-7,2 l / 100 km.
I think this is a great result for a 28 year old car!
cherniy_chack
Postby cherniy_chack » Mon Sep 24, 2018 2:29 pm
I found rust on the left front threshold.
He punched a hole with his finger, then with a hammer.
For a very long time I could not begin the repair.
But he did.
https://fordtransit.club/uploads/monthl ... 5a493c.jpg
https://fordtransit.club/uploads/monthl ... ea2bcb.jpg
I did not clean the seam on the doorstep-just laziness.
cherniy_chack
Postby BROWNYS V6 » Thu Sep 27, 2018 10:10 pm
had a runout in the van tonite to a ford meet at a pub
BROWNYS V6
Postby BROWNYS V6 » Sun Sep 30, 2018 9:45 pm
new springs on yesterday, feck all today :)
BROWNYS V6
Postby Mk5swbhighroof » Fri Oct 05, 2018 1:50 pm
Got a fresh MOT :D :D
Failed last week, had welding done, replaced the off side front break caliper and bled the system.
Oil change next.
Mk5swbhighroof
Postby BROWNYS V6 » Wed Oct 10, 2018 7:10 pm
sod all today, had a runout to the Essex rs meet last nite at the halfway house, it was packed out, a good nite :)
BROWNYS V6
Postby Kjeles » Wed Oct 10, 2018 7:55 pm
Replaced the clutch plate. And surprise: the old clutch plate was mounted the wrong way. No wonder the clutch did not feet good.
By the way. Made a handy gear box cart from a piece of wood, four lawn mower wheels and two old jacks. Really easy to dis- and reconnect the gear box from/to the engine.
Kjeles
Postby meandthedog » Thu Oct 11, 2018 8:31 pm
I bought mine off ebay a 2000 campervan and then I joined your forum hello folks
meandthedog
Postby vanfox » Sat Oct 13, 2018 10:05 am
Finally decided the minibus is toooo far gone to repair so started to prepare it for the final journey. Drained half a tank of diesel by idling the motor with the I.P. fuel return pipe running into a big container or several. Blocked the filter where it usually fits. The lift pump really moves a lot of fuel, only took 30 mins, leaving enough in the tank to move the bus to where the scrap man can load it.
Anyone want SWB minibus windows etc
vanfox
Postby gotgcoalman » Sat Oct 13, 2018 4:22 pm
Kjeles wrote:Replaced the clutch plate. And surprise: the old clutch plate was mounted the wrong way. No wonder the clutch did not feet good.
That's the girls way of doing it :lol:
laid on your back with the box on your chest is the propper way :D
*wish I'd had one of those when I did my clutch last year :lol:
meandthedog wrote:I bought mine off ebay a 2000 campervan and then I joined your forum hello folks
Hi and welcome 8)
vanfox wrote:Finally decided the minibus is toooo far gone to repair so started to prepare it for the final journey. Drained half a tank of diesel by idling the motor with the I.P. fuel return pipe running into a big container or several. Blocked the filter where it usually fits. The lift pump really moves a lot of fuel, only took 30 mins, leaving enough in the tank to move the bus to where the scrap man can load it.
Sorry to hear that.
I had to admit defeat on my last van :(
Not today (yesterday) did 162 uneventful miles delivering coal in mine :)
Too bloody quiet :shock:
gotgcoalman
Postby BROWNYS V6 » Sat Oct 13, 2018 5:33 pm
Drove it :)
BROWNYS V6
Postby Mk5swbhighroof » Sun Oct 14, 2018 7:47 pm
Bodged the prop centre bearing to last a little longer untill a replacement can be fitted :oops:
Mk5swbhighroof
Postby BROWNYS V6 » Sun Oct 14, 2018 7:49 pm
found more rust to fix :roll:
BROWNYS V6
