Frag wrote:I think you'll find it would be unsafe,nigh on deadly,with nothing to reduce and compensate rear brake pressure..
I bypassed the valve on my old mk3 escort van temporarily as it was leaking,
Slightest touch of the brakes and it would lock up and 'swap ends'
bigjohnthomas wrote:I thought campers run on the weight limits with all that stuff you weirdos carry around with you ?
I reflected about binning the one on sooty but what about the
mot regs section 3.6 Moi E2 RfR 2 ? if the internet served my correctly you are commuting a castratable offence
regards
s m Allcock
bigjohnthomas wrote:that sounds light my little van is 2000kg empty
apart from me in it
regards
fat b*stard Allcock
hornhead wrote:was gonna do a my LAV hell part2...
fitted fixed valve after agreement with insurance as its camper...drives better than ever,really fine adjustment on Wilwood valve
However van safer than ever and still no MOT...they can't deal with it ffs![]()
so after quote of nearly £700 for recon from Germany and they refuse to sell kitI have mine apart, traced it as a Lockheed part, Northwest classic looking for seals.
If you remove,undo at pivot leaving long spring fixed to axle or you're in for hgv style setup fun
I will post a how to rebuild if I get sorted
(Mine is late mk3 variant...fair amout of mk2 and mk5 on ebay btw)
