Losing power on hills
Postby oirishman » Sun Sep 24, 2017 9:49 pm
Hi i,m new here...hope someone can help..i have a 1999 ford transit 2.5 turbo it runs well on the flat but if it hits even a slight hill it dies off dramatically...no black smoke..i have to gear down to 2nd sometimes..any ideas would be appreciated.
oirishman
Re: Losing power on hills
Postby CamperMad1 » Mon Sep 25, 2017 12:44 am
Happened to mine 2.0 petrol after changing carb and everything else ended up being one cylinder down :-( .so i recommend a compression test before spending any time or money
Sent from my SM-G935F using Tapatalk
CamperMad1
Postby Jim Archer » Mon Sep 25, 2017 7:02 am
When did it last have a good service?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby oirishman » Mon Sep 25, 2017 7:38 am
Not for a long time jim.what is involved in a good service.....
oirishman
Postby ricc » Mon Sep 25, 2017 9:03 am
engine air filter....and make sure inlet duct is clear and clean
fuel filter
engine oil and filter
are the basics and fix most
dont forget the timing belt if it hasnt been done in living memory
then getting more expense and hassle , valve clearances , recon injectors
ricc
Postby KING OF ENGLAND » Mon Sep 25, 2017 9:29 am
Good service is the answer as already said
Sometimes the torque sleeve sticks so 2 stroke in the fuel will sort that
Mines a non turbo and will quite easily go up hills at 70mph without problem
Service every 6000 miles and banana of and cleaned every year and my egr valve
Is still connected
KING OF ENGLAND
Postby Jim Archer » Mon Sep 25, 2017 6:01 pm
I reckon it probably just wants a fresh fuel filter and valve clearances done, but a properly timed shiney new cambelt certainly won't hurt.
Jim
Jim Archer
Postby Tolley » Tue Jun 24, 2025 12:43 pm
Did you fix it ?
Tolley
