ABS master cylinder part no.
Postby MinorMatt » Tue Oct 03, 2017 6:03 pm
This post is really just to record info for thos who use the search facility.
The ABS Master Cylinder on my 1996 van failed. I believe it is the same part number for all pre 1997 transits with ABS.
The ATE part number on the side is 10.6123-0150.3 when searching for this no results can be found (i.e. not available anywhere). The ford FINIS no for it is 7143733. Ford no longer have a stock (no suprise there).
But the original ATE part no. Has been superceeded to 10.6123-0154.3 - which is readily available (but not cheap)
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Re: ABS master cylinder part no.
Postby focusp » Tue Oct 03, 2017 7:57 pm
the twin pot non abs cylinder not the same then may have one of those in shed saw your facebook post yesterday
focusp
Postby MinorMatt » Tue Oct 03, 2017 9:13 pm
No they arn't :(
2 x 2006 Mk7s
Postby bambi mk 1 » Wed Oct 04, 2017 6:15 pm
Are you looking for one Matt :?: One here :)
bambi mk 1
Postby MinorMatt » Wed Oct 04, 2017 8:10 pm
Bought one now - but if I see another new one cheap I will get it and keep it
2 x 2006 Mk7s
Postby bambi mk 1 » Wed Oct 04, 2017 9:37 pm
I will keep it for you Matt and let you know when I'm heading over :)
bambi mk 1
Postby MinorMatt » Fri May 23, 2025 11:34 am
Just a thought - but have you still got it Bambi? :)
2 x 2006 Mk7s
