2.5di to 2.5 td
Re: 2.5di to 2.5 td
Postby simon68 » Sun Apr 15, 2018 11:28 pm
Thanks for the info i shall definitely look at what diff i have.
Also going to change the fuel filter as advised, as i believe the van has been sitting a while.
simon68
Re: 2.5di to 2.5 td
Postby cherniy_chack » Mon Apr 16, 2018 7:26 pm
simon68 wrote:Also going to change the fuel filter as advised, as i believe the van has been sitting a while.
Change, there will be no harm.
"Thoughtfulness" of the motor can be associated with late injection or improper adjustment of injection pump.
cherniy_chack
Re: 2.5di to 2.5 td
Postby simon68 » Mon Apr 16, 2018 7:29 pm
thanks cherniy_chack.
Just dealing with a cracked thermostat housing now :cry:
looking at photos of engines i've noticed i'm missing a 'rod' that goes from pump to manifold? what does that do?
simon68
Re: 2.5di to 2.5 td
Postby gotgcoalman » Tue Apr 17, 2018 10:06 pm
simon68 wrote:thanks cherniy_chack.
the rod opens the butterfly in the inlet.
If it's missing the egr has more than likely been blanked off.
If the butterfly is present and closed with no rod to open it................. :( air starvation.
Mon chien n'a pas de nez. :shock:
kangaroos can't walk backwards :wink:
gotgcoalman
Re: 2.5di to 2.5 td
Postby cherniy_chack » Wed Apr 18, 2018 7:32 pm
If there is no "rod" connecting the lever to the injection pump and the "butterfly" in the manifold, the car does not go and smokes strongly with black smoke.
It is necessary to remove the rubber hose at the entrance to the manifold and see the state of the "butterfly".
It can be fixed in the open state or dismantled.
You call this kind of manifold "banana"?
https://besplatka.ua/aws/8/25/00/85/aea559483cfb.jpg
We call this "crab".
cherniy_chack
Re: 2.5di to 2.5 td
Postby simon68 » Wed Apr 18, 2018 8:22 pm
thanks for that.going to get a mechanic friend to take a look for me.I contacted last owner about the rod missing and he just said most people remove them for extra power.So he wasn't a great help
simon68
Re: 2.5di to 2.5 td
Postby simon68 » Wed Apr 18, 2018 8:27 pm
I don't have a banana inlet on my 2.5di....guess mine is an earlier engine?
simon68
Re: 2.5di to 2.5 td
Postby gotgcoalman » Wed Apr 18, 2018 10:19 pm
simon68 wrote:I don't have a banana inlet on my 2.5di....guess mine is an earlier engine?
Post a pic :D
gotgcoalman
Re: 2.5di to 2.5 td
Postby cherniy_chack » Thu Apr 19, 2018 5:30 am
Hi,gotgcoalman!
On my photo is "banana"?
cherniy_chack
Re: 2.5di to 2.5 td
Postby gotgcoalman » Thu Apr 19, 2018 5:39 am
cherniy_chack wrote:Hi,gotgcoalman!
yes the photo is of what we call a banana engine :D
gotgcoalman
Re: 2.5di to 2.5 td
Postby cherniy_chack » Thu Apr 19, 2018 4:04 pm
gotgcoalman,thank!
simon68, you have like manifold?
cherniy_chack
Re: 2.5di to 2.5 td
Postby simon68 » Fri Apr 20, 2018 12:21 pm
Hi Cherniy,yes that's what i have.
My friend checked the inlet butterfly for me and cable tied it open.The egr wasn't blanked off so he made a plate for me and has fitted it.Hopefully this will help :)
Just waiting to fit a new fuel filter and Thermostat housing later today(cracked)
So is the Banana inlet an improvement on the other type?
simon68
Re: 2.5di to 2.5 td
Postby vanfox » Fri Apr 20, 2018 3:13 pm
If you have the 5.14 diff and plenty of money / desire to lower the engine revs / increase top speed you could add a Laycock J type overdrive after the MT 75, as I have. Fairly simple bolt on job. My Smiley with a 4.11 diff does 70 mph at 2500 in overdrive.
This is well suited to long wheel base camper vans with the TDi engine?
There's pics on here.
The banana inlet was an attempt to introduce a ram inlet effect to increase the BHP. Added all of 3-4 BHP I believe.
The green bit on the rev counter is the alleged economic rev range, similar to turbo charged HGVs...ha.
vanfox
Re: 2.5di to 2.5 td
Postby simon68 » Sun Apr 22, 2018 8:13 pm
Thanks for that Vanfox :) I shall check out the pics! Took it out today and the clean air filter(old one was well clogged up)& the EGR blanked off has definitely made a difference in acceleration.Felt like a different Van.I was doing about 65mph at 3000 revs so i guess it will do 70 within the 4000 rpm limit.I do like the sound of an overdrive though :)
simon68
Re: 2.5di to 2.5 td
Postby blizard » Wed Apr 25, 2018 2:51 pm
I did an engineswap also.
This winter I replaced the whole exhaust with Turbo accomodating 6,5 cm pipes. That differs a lot!
Transit MK3 1987
Chausson Motorhome
Engine 2.5TD of 2000 (last production year of the DI, I'm told)
Gearbox MT75
blizard
