Engine will not rev
Engine will not rev
Postby Wayne Bywater » Sun Apr 22, 2018 5:03 pm
After changing the diesel pump the engine will run on easy start but it wont rev up.
the year is a 1997 banana engine 2.5 litre non turbo.
I pinned the engine using 3 pins than took the diesel pump off and replaced.
Wayne
Wayne Bywater
Re: Engine will not rev
Postby cherniy_chack » Sun Apr 22, 2018 7:55 pm
The motor is easily started, but does not gain momentum?
Do I understand correctly?
cherniy_chack
Postby gotgcoalman » Sun Apr 22, 2018 8:15 pm
Have you got fuel to the injectors?
Mon chien n'a pas de nez. :shock:
kangaroos can't walk backwards :wink:
gotgcoalman
Postby cherniy_chack » Mon Apr 23, 2018 5:13 pm
Motor is starting,but no rev up.
I do correctly understand?
cherniy_chack
Postby gotgcoalman » Mon Apr 23, 2018 6:14 pm
cherniy_chack wrote:Motor is starting,but no rev up.
from the first post it'll run on easy start but not after the spray has been burnt.
I might be wrong though.
gotgcoalman
Postby davetheshrew » Mon Apr 23, 2018 9:17 pm
takes ages to get fuel up mate, be prepared to flatten a battery. on side of the pump is a bleed off port, loosen it then crank the engine untill fuel pisses out and close it, you will now have fuel in the pump. One tip I got is to fit a one way valve high up on the fuel feed to the pump and you never have to do this again.
davetheshrew
Postby gotgcoalman » Mon Apr 30, 2018 5:09 pm
well he's either sorted it or died trying :wink:
Sun Apr 22, 2018 4:48 pm
Last visited:
Sun Apr 22, 2018 6:54 pm
1 | Search user’s posts
(0.00% of all posts / 0.12 posts per day)
gotgcoalman
Postby E15mas » Sun Oct 07, 2018 7:04 pm
Did u get this sorted if so any help mines coin the same runs really rough when it starts it will no rev very hard at all and revs slowly can get it to about 3000rpm but after a few seconds they drop off and it tries to die tried feeding it from a jerry can directly to the pump and its still the same any help would be great
E15mas
