4DA banana engine timing belt kit
Postby eastkent » Wed Apr 25, 2018 2:59 pm
Could someone please tell me which belt I need?? There's so many different ones!
Also, I'm sure I remember seeing a how-to related to this but I can't seem to find it now...
Many thanks.
eastkent
Re: 4DA banana engine timing belt kit
Postby gotgcoalman » Wed Apr 25, 2018 4:01 pm
https://www.ebay.co.uk/itm/Gates-Timing ... #vi-ilComp
Just a case of checking compatibility.
4DA engine 59kw :)
Mon chien n'a pas de nez. :shock:
gotgcoalman
Postby cherniy_chack » Wed Apr 25, 2018 7:39 pm
You need a belt with a tooth height of 3.5 mm (M-shaped profile) with a width of 25.4 mm. I do not know the number of teeth.
Up to 92 years the height of the tooth is 2.5 mm, width 25.4 mm.
After 98 years for TD the height of the tooth is 3.5 mm, the width can be 28 mm.
cherniy_chack
Postby eastkent » Wed Apr 25, 2018 8:15 pm
Thanks. I've become quite suspicious of compatibility lists where this van is concerned.
eastkent
Postby gotgcoalman » Wed Apr 25, 2018 10:30 pm
eastkent wrote:Thanks. I've become quite suspicious of compatibility lists where this van is concerned.
remmber a previous owner might have changed the engine though :wink:
gotgcoalman
Postby vanfox » Thu Apr 26, 2018 9:14 am
Best you can do is buy both belts/kits with the agreement you can return the wrong one unopened. As mentioned you may have a newer/older engine. The Haynes book has good description of how to change the belt.
vanfox
