MK5 Crown Wheel & Pinion
Postby steverk » Tue May 01, 2018 11:26 am
I am looking at fitting a MK3 crown wheel and pinion with a higher ratio into my MK5 differential - I have heard that there are differences between MK3 and later MK5 axles I think to do with half shaft diameters but its not clear if this includes differences with the crown wheel and pinion parts.
I would retain the current differential housing and planet gears etc and just swap the crown wheel and pinion gears.
Would this work or are the gears different???
Any pointers on this would be much appreciated
Steve
steverk
Re: MK5 Crown Wheel & Pinion
Postby cherniy_chack » Tue May 01, 2018 3:32 pm
Someone at this Forum offers diff 4.1.
What kind of gear do you have and what interests you?
cherniy_chack
Postby MinorMatt » Tue May 01, 2018 6:14 pm
So long as its the same axle type cw&p interchangeable
95 M Ford Prototype/Mule DRW 100PS Highcube
96 N 120 Turbo'd DI SWB Low
96 P 150 TD (100PS EPIC) LWB Hi-Top
Lucas laser 2000 & IDS onwner
Gaffa tape is like the force - it has a light side, a dark side, and it holds the universe together.
Postby cherniy_chack » Tue May 01, 2018 6:26 pm
Axes type H MK3 and MK4, MK5 are not interchangeable.
Replacing defa requires some works that are not very complex, but require expertise and knowledge.
I was engaged in such a replacement, I know.
cherniy_chack
Postby steverk » Tue May 01, 2018 9:56 pm
My current axle is 4.56:1 the standard ratio. The van never carries any weight. To change the crown wheel and pinion will require (possibly) revised shims and or 'crush' washer to ensure proper meshing but the original star gears and housing will remain as per original. Going for a 4.11:1 ratio will ultimately provide an extra 10 MPH at 70-80MPH although I tend to drive it at around 56MPH in lane 1 following the LGVs. A 4.11:1 diff' will give 2-3 MPH increase (at 4,000RPM) in first, 3-4 in second etc. up to 5th gear with a drop of around 300 RPM at 60 which although doesn't sound much is audibly noticeable.
steverk
Postby cherniy_chack » Wed May 02, 2018 5:47 pm
Hello, steverk.
Replacing the gearbox 4.56 by 4.1 or 4.11 will give an increase in speed with the same engine speed by 11%, and increase the real mileage by 11% with the same odometer reading. This should be taken into account when speed limits are limited and fuel consumption is calculated.
The fuel consumption will decrease by approximately 5%.
Reducer (diff) 4.11 was used on MK3, gearbox 4.1 on MK4 and MK5.
Reducer 4.1 can be installed on your MK5 without any problems.
If you find a reducer 4.11, then to install it on your MK5 you will need
interchange the boxes of differentials and gears.
On the gearbox MK3 4.11 it will be necessary to install a differential box from the MK5 4.56 reducer, while leaving the gear wheel MK3.
It is not difficult.
Then it will be necessary to adjust the clearance in meshing.
This is also not difficult.
Then install the gearbox on the axle.
Reducer = diff.
cherniy_chack
