MK4 CAV SYSTEM
MK4 CAV SYSTEM
Postby billyboy » Sat May 12, 2018 11:18 am
Can anyone help with a little broken link on my daughters van. IT was all of about 2cm long, now in two parts. The first pic shows half of the broken bit. The last pic shows the plastic link that clips onto the ball end.
It should crank up the tickover for cold starts.
Can I fit an oldy worldly choke knob to attach to the accelerater cable.
Any help would be helpful.
Bill
billyboy
Re: MK4 CAV SYSTEM
Postby billyboy » Tue May 15, 2018 9:10 pm
billyboy wrote:Can anyone help with a little broken link on my daughters van. IT was all of about 2cm long, now in two parts. The first pic shows half of the broken bit. The last pic shows the plastic link that clips onto the ball end.
Bill
Does anyone have an old CAV pump at the back of the shed............ might be worth a tinnie or two or few.
Bill
billyboy
Re: MK4 CAV SYSTEM
Postby V184 » Tue May 15, 2018 9:14 pm
used to be able to get it as a kit from Lucas dont know if you still can ?
V184
Location: You're right, V184 is an arsehole with a chip on his shoulder........
Re: MK4 CAV SYSTEM
Postby billyboy » Wed May 16, 2018 7:41 pm
V184 wrote:used to be able to get it as a kit from Lucas dont know if you still can ?
ok thanks , I'll check it out
billyboy
