Transponder antenna
Transponder antenna
Postby PaulD078 » Sat May 12, 2018 9:33 pm
Any helpful souls out there know where I can get one of these. Nearest Ivan get is one on eBay for Mk 6 looks same but slightly different part no
The one I'm after is
97vp-15607-aa
Paul
PaulD078
Re: Transponder antenna
Postby MinorMatt » Sun May 13, 2018 7:56 pm
Think I've got a spare... will go for a quick rummage after dinner
95 M Ford Prototype/Mule DRW 100PS Highcube
96 N 120 Turbo'd DI SWB Low
Lucas laser 2000 & IDS onwner
Postby PaulD078 » Sun May 13, 2018 8:28 pm
Fantastic
Sent from my Moto G (4) using Tapatalk
PaulD078
Postby PaulD078 » Mon May 14, 2018 6:19 pm
Have tried local Ford dealer, eBay and national search site for Transits and I success with this. Does anyone think it would be possible to either use the Mk 6 transponder which is available on eBay or to replace the ignition unit with an unchipped one which I can also get ( ignition barrel and keys)? Thanks for any advice. Paul
PaulD078
Postby PaulD078 » Mon May 14, 2018 7:10 pm
Thanks to MinorMatt for sorting this out for me. Apparently the Mk6 one works and I now have few options for purchase.
PaulD078
Postby MinorMatt » Tue May 15, 2018 7:58 pm
I didn't say a mk6 one works...
The ones I pointed at were mk5. Might have been carryover to mk6 though...
Postby PaulD078 » Tue May 15, 2018 9:15 pm
Sorry if I've missed anyone but Ithink it's as you say...the genuine Ford part you directed me to says works for Transits 94-06 so must be good for both. Thanks again.
PaulD078
Postby Frag » Tue May 15, 2018 10:24 pm
If the mk6 one doesn't work,I'll likely have a mk5 one but will have to check...
Frag
Ford Technician
Postby PaulD078 » Tue May 15, 2018 10:29 pm
Thanks will let you know. Assuming it's the transponder that's faulty but that looks most likely at the moment
PaulD078
Postby Frag » Tue May 15, 2018 10:57 pm
What's the actual fault,
Oh and is this turbo or not,as the pats system works differently
Frag
Ford Technician
Postby PaulD078 » Tue May 15, 2018 11:15 pm
Fault is sometimes struggles to start either sounds like turning over or no sound at all. Had new battery and starter motor last year. My friend is a mechanic and says he's seen similar issues resolved by changing the transponder antenna. I tried to get auto electrician to look at it he's not been in touch yet but said it would take a few days in his workshop to assess so change of transponder seems cheaper option to try first. It's a 2.5 DI pulling 3.5tonne Autosleeper motorhome am pretty sure it's a Turbo. Thanks for the interest
PaulD078
Postby Frag » Tue May 15, 2018 11:26 pm
If the pats receiver was faulty,the immobiliser LED will flash rapidly when you turn ignition on,then if left will eventually flash a 2 digit fault code.
If,when you turn ignition on,the led comes on for a couple of seconds and goes out,the fault is not pats / immob. Related.
Could possibly be poor connections at battery lead ends,or poor main earth to engine,they break down internally but look ok.Substituting lead with a jump lead when is 'faulting' will tell you.
Frag
Ford Technician
Postby PaulD078 » Wed May 16, 2018 5:45 pm
At risk of appearing stupid I can't see an immobiliser LED on my dash. There is a flashing red light above the internal courtesy light console which goes solid for a few seconds then goes off after ignition key turned but that's about it? Thanks.ImageImage
PaulD078
Postby twin wheel camper » Wed May 16, 2018 6:12 pm
Then it not your immobiliser causing your problems. Like already said it will rapid flash to show a fault if it’s not doing that then the key code is being read correctly.
twin wheel camper
Postby PaulD078 » Wed May 16, 2018 7:57 pm
No idea why but it just started 4times on the trot. Then refused and the LED started flashing fast before flashing 32 anyone know how to fix this please!? Thanks
PaulD078
