Diff oil for mk5
Diff oil for mk5
Postby Nonsense » Sun May 13, 2018 8:33 pm
Hi, I'm currently servicing my 1995 2.5di transit and about to purchase mt75 oil for the transmission. But what about the differential oil? What grade it should be or is it some special oil?
Nonsense
Re: Diff oil for mk5
Postby gotgcoalman » Sun May 13, 2018 8:52 pm
90 EP or 85w-90 (GL5)
Mon chien n'a pas de nez. :shock:
kangaroos can't walk backwards :wink:
gotgcoalman
Postby Nonsense » Sun May 13, 2018 9:08 pm
gotgcoalman wrote:90 EP or 85w-90 (GL5)
Thank you, do you know the oil capacity of the diff by any chance? 1-2-5 litres? :D I have never changed a differential oil before.
Nonsense
Postby Mr RVM » Mon May 14, 2018 12:49 am
Fill through plug hole in back of casing till it comes out....then it's full.... :wink:
Originally Restorationvanman
Mr RVM
Postby gotgcoalman » Mon May 14, 2018 9:57 pm
depending on which axle is fitted.
1.7-2.7 litres.
gotgcoalman
Postby vanfox » Thu May 17, 2018 2:25 pm
Has anyone ever completely changed the diff oil?
The "H" axle has no filler plug on the axle case, the level plug is on the side of the diff carrier. Clean the crap away first!
vanfox
Postby Chuggy » Thu May 17, 2018 11:39 pm
you can use a mightyvac, or brake vacuum, or big syringe, bit of a feck about and you'll never get it all and it stinks and is orrible and sticky
Chuggy
Postby dumper » Fri May 18, 2018 7:14 am
Did mine at work once used a sealey vac oil changer did it after a run but still slow to pull oil out and once at home while relineing brakes and hub seals I got a gasket and pulled prop and diff out and cleaned all oil out just cost bit of time and a gasket
