bosh pump
bosh pump
Postby samsonv18 » Wed Aug 01, 2018 7:38 pm
hi all just changed my Lucas dribbler pump to a bosh , on the 2.5 di . starts and runs fine apart it blacks smokes .can i turn the fuel down if so how
samsonv18
Re: bosh pump
Postby Chug » Wed Aug 01, 2018 11:00 pm
Welcome to the forum
link below for info on where the pump fuel adjustment screws are:-
viewtopic.php?f=2&t=185357&hilit=tuning+bosch&start=60#p1596278
Chug
Re: bosh pump
Postby samsonv18 » Thu Aug 02, 2018 7:04 am
thank you
will try that today as we go away for the weekend to a steam rally :D
samsonv18
Re: bosh pump
Postby joinerman » Thu Aug 02, 2018 6:57 pm
Where ya going ? Shabbington !
joinerman
Re: bosh pump
Postby samsonv18 » Fri Aug 03, 2018 9:07 am
Reduce smoking very poor revs now
Steam rally is in oxsford March
samsonv18
Re: bosh pump
Postby gotgcoalman » Fri Aug 03, 2018 3:06 pm
Turn fuel up slightly until a decent compromise is achieved.
Or turn fuel back up to "smoke with poke" setting and get more air into the engine
to help burn the extra fuel.
You're setting off in plenty of time it's only August :wink:
Too bloody quiet :shock:
gotgcoalman
Re: bosh pump
Postby samsonv18 » Fri Aug 03, 2018 7:20 pm
:D
samsonv18
Re: bosh pump
Postby samsonv18 » Thu Aug 23, 2018 7:50 pm
samsonv18 wrote:thank you
first i have the pancake engine ,the pump is from a banana engine is there any difference in timing
samsonv18
Re: bosh pump
Postby thanuttiscotsman » Fri Aug 24, 2018 5:06 pm
If it's a mk5 smiley then I'm positive the Lucas and Bosch pump have a diff firing order. Sure I had to swap two injection pipes round when I did pump conversion.
Rossco
1996 transit swb 80 2.5di
1989 bx 16 valve gti nos and all the rest!
thanuttiscotsman
Re: bosh pump
Postby samsonv18 » Thu Sep 06, 2018 7:05 am
i had the pipes with the pump , it runs ok just lacking power . may be time to look for a banana engine
samsonv18
Re: bosh pump
Postby Jim Archer » Thu Sep 06, 2018 7:45 am
Did you change the injectors to suit?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Re: bosh pump
Postby samsonv18 » Thu Sep 06, 2018 4:54 pm
yes all came from the original engine
samsonv18
Re: bosh pump
Postby vanfox » Thu Sep 06, 2018 6:59 pm
Did you pin the fly, cam and IP before installing the belt? Did you slightley loosen the 4 IP sprocket bolts to allow the belt to settle under tension? If you did all that try this.
Pin the engine again, slightley loosen the 4 sprocket bolts, noting where they are in their slots. Put a spanner on the IP hub, withdraw the IP pin and advance the IP clockwise by 1 mm measured in the IP sprocket pulley slots. Tighten the 4 bolts whilst holding the IP in the new position. Pull the other pins out and try to start the engine. If it kicks back it's too far advanced, revert to the previous pinned setting. If it runs watch for smoke. It's suck it and see time as far as how much advance to use, 1 mm won't do any harm. If no smoke try turning up the fuel, check for smoke and performance.
NB. A banana won't run much better than a properly set up pancake.
As I said, suck it and see.
vanfox
Re: bosh pump
Postby samsonv18 » Fri Sep 07, 2018 6:09 pm
set up as first , will try next step thank you
samsonv18
Re: bosh pump
Postby Harry_Viderci » Tue Sep 11, 2018 7:19 am
I am only a newbie to this game so excuse me if I am wrong, but I would have thought that if you hold the belt still and rotated the inj' pump shaft clockwise then you would be retarding the injection timing rather than advancing the injection timing. Hope I haven't confused the issue.
Sent from my D5803 using Tapatalk
Harry_Viderci
