pump replacement Mk5 smiley 1997 190 2.5D
Postby 97transit2.5D » Sat Aug 25, 2018 12:02 pm
Hi mk5 experts
have coolant coming out from under cam cover. suspect pump leakage.last changed 70,0000km 13 years ago.
does anyone have pictures of whats involved...i understand removing the timing belt is not required.
came across this
http://www.fordtransitforum.co.uk/forum/viewtopic.php?f=2&t=19303
are there pictures..i do have a haynes manual.....also does anyone have a source of parts of their transit online
i found this
https://www.onlinecarparts.co.uk/
what are the best brands for water pump,timing belt and tensioner....does water pump come with o rings??
97transit2.5D
Re: pump replacement Mk5 smiley 1997 190 2.5D
Postby dumper » Sat Aug 25, 2018 9:32 pm
The water pump is a gasket I always use blue hylermar on gasket or similar sealent as for removing the pump remove the grill drain and remove radiator remove viscous fan and then pulley then the alternator belt cam cover then remove the pump as for make of pump the last one I used was ford but try local factors I am not a fan of eBay may be cheaper but if you get a bad one it’s easier to sort it local
Postby gotgcoalman » Sun Aug 26, 2018 8:14 am
Put an FAI pump on mine about 3 years ago.
About 30 quid from local motor factor.
Too bloody quiet :shock:
gotgcoalman
Postby 97transit2.5D » Sun Aug 26, 2018 9:07 am
can you explain why my haynes has a 4 wrench out of 5 difficulty in timing belt replacement compared with water pump 2 wrench out of 5..dont you loosen a tensioner to slacken the rubber belt then tension refitted belt and done??..is the tensioning just a check of deflection of tensioned belt with ruler.??apologies if i have made this sound simple.Rick.
97transit2.5D
Postby 97transit2.5D » Sun Aug 26, 2018 9:16 am
ford part numbers for mk5 smiley
water pump kit ME914F8591A2B
timing belt 924F6K288AA
pully tensioner 844F6K254A1A
rear brake shoe.280mm15inch94VB2200BB
I PUT all of these codes into onlinecarparts.co.uk and it gives you every manufacturer of that part.
hope that helps
97transit2.5D
Postby gotgcoalman » Sun Aug 26, 2018 12:48 pm
97transit2.5D wrote:can you explain why my haynes has a 4 wrench out of 5 difficulty in timing belt replacement compared with water pump 2 wrench out of 5..dont you loosen a tensioner to slacken the rubber belt then tension refitted belt and done??..is the tensioning just a check of deflection of tensioned belt with ruler.??apologies if i have made this sound simple.Rick.
No need to disturb the timing belt.
There's enough wiggle room :idea:
gotgcoalman
Postby gotgcoalman » Sun Aug 26, 2018 3:38 pm
Ahhhha don't think I took the fan off either.
Just used a socket extension through the fins :D
gotgcoalman
Postby dumper » Sun Aug 26, 2018 9:14 pm
I got the proper viscous fan spanner years ago so I use it but can do without it but if doing belt gives you more room
Postby 97transit2.5D » Sun Aug 26, 2018 9:50 pm
thks gotgcoalman for pic...brill
can you comment why putting on a new timing belt is SUPPOSEDLY such as mission???
97transit2.5D
Postby dumper » Mon Aug 27, 2018 10:15 am
The timeing belt on a di must be one of the easiest to do and if you get it wrong you are not going to do a lot of damage to the engine bent push rods or snapped rocker arm if you follow the how to link on hear you will not go wrong
Users browsing this forum: dumper
