Rear hub nut
Rear hub nut
Postby mrfixit » Sat Sep 01, 2018 4:01 pm
Want to replace the brake shoes on my 1997 twin rear wheel tranny, the manual says the hub is held by a 21/4" nut, when I stated the size to my local tool shop he said is it for a transit I stock them, it's 56mm but it's not large enough, any body else had this please?
mrfixit
Rear hub nut
Postby 100ps_drw_hicube » Sat Sep 01, 2018 5:24 pm
Hi you don’t need to remove hub to do rear shoes not long done mine. I ended up getting new drums as they were really worn I think from memory the twin wheel hub nut is 65mm?
100ps_drw_hicube
Transit Abuser!!
Re: Rear hub nut
Postby dumper » Sat Sep 01, 2018 8:43 pm
If you can have the van off the road while you do it remove half shaft bend the lock tabs back and use blunt chisel to remove the nut and take it to tool shop to get you the correct socket when I did mine years ago I made my own by bending inch flat bar around the nut and then welding it a old socket
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Rear hub nut
Postby MinorMatt » Sun Sep 02, 2018 3:16 pm
Its a 65mm bi hex thats needed
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
