by loot » Thu Sep 13, 2018 8:45 pm
Relays, grounds? ignition switch? Although unlikely if no lights at all.
You really need to get a tester on it and pin point around the fuseboxes to narrow the search.
You can use a bulb tester too, ground the lead end and touch things to locate the end of line power.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
07 350 170ps
Ids v86 licence + v86.04 update + xprog
hereIds map
here
