Hi guys..... long time no see!
Finally got around to putting my mk3 lsd axle into my mk4.
Using mk4 brakes so i've swapped all that hardware over and welded the bracket for the LAV in the right place, as well as cutting the damper mounts off turning them around and welding them back in place.
Everything lines up lovely....except the wheels with the arches!
I've long since got rid of the mk4 casing but from memory it was only a couple of inches wider than the mk3 one... but now i've fitted it the wheel looks to be about six inches inside the arch, and the inner arch fouls the wheel by about an inch and a half!
Have i got something wrong or do i need to space the wheel out or tub the arches?
Ta.
