Hi, I just noticed that my rear fog lamp works with both dip & main beam. I am sure it hasn't always been like this & I have not done any electrical work on it for years. (I have owned the van since 2005)
Everything seems to work as it should, Comes on with ignition & main/dip selected on the right stalk but does not go off when main is selected with the left.
Yellow indicator lamp indicates correctly when the lamps are on. Disconnecting main/dip selector at the plug makes no difference. Lamp is enabled as soon as ignition & right stalk is engaged.
I have looked through the diagrams in the Haynes manual but cant see where the power can be coming from in main beam mode..
Anyone shed any light on this issue?
Cheers
Bill
PS LTNS
