front brake pads
front brake pads
Postby baxi » Tue Sep 11, 2018 11:20 am
anybody know if there is different thickness of brake pads for transit smiley - as even when pistons are pushed back in can not fit 2 new pads together , dia - 12mm material . ? .
baxi
Re: front brake pads
Postby Altransit » Tue Sep 11, 2018 1:52 pm
Did you push them back in, with the top off the reservoir :?:
You may need to grind off the rusty top on the outside of the disc, unless they're new ones :?:
Postby MinorMatt » Tue Sep 11, 2018 6:53 pm
Yes.
Pads for 6 stud vans have more material on them - but otherwise the same
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Users browsing this forum: Clive Muir
