egr blanking
egr blanking
Postby jono40 » Sat Sep 22, 2018 1:33 pm
hi all well my first transit motor home need a bit info I just blanked off egr vale and I here you have to tie the butter fly open could do with a few pics if possible . my transit is 95 mk5 2,5 td with epic injection I think . cheers john :D
jono40
Re: egr blanking
Postby INTRANSIT » Sun Sep 23, 2018 6:55 pm
look towards the bottom of this post
viewtopic.php?f=18&t=3968
Mk7 2.2 85ps Fwd 2008 poverty spec
INTRANSIT
Re: egr blanking
Postby wojciech » Sun Sep 23, 2018 9:31 pm
INTRANSIT wrote:look towards the bottom of this post
Link is about 2,5D with Bosch, jono40 has Lucas EPIC... :?
In EPIC EGR (with position sensor) and throttle plate are actuated by vacum, CVT valve and PCM. It is quite different system as with fully mechanical Bosch pomp.
If you blanked EGR with metal plate - that's the best you can do.
wojciech
Re: egr blanking
Postby jono40 » Mon Sep 24, 2018 6:56 pm
thanks for the reply I have blanket the egr and cable tied the buttery fly open and runs sweet I hope just change fuel filter a bit jellified mmmmmm took him out for a run no smoke . but I am going to change to a manual pump and get rid of the epic system just need to find out witch one I need thanks john
jono40
Re: egr blanking
Postby Fo-Banshee » Fri Oct 12, 2018 9:41 pm
i also have a 2.5tdi with the epic and I have put in the egr blanking plate. Should I also fix open the butterfly plate or remove it or just leave as is? cheers John
Transit VG 07/2000 4EB 2.5tdi Mid roof Lwb (camper), VG 1999 3.8ltr V6 LWB, VG 1997 3.8ltr V6 LWB and a Transit VG 09/1996 4EB 2.5tdi Low roof Swb (spare parts)
Fo-Banshee
Re: egr blanking
Postby wojciech » Sat Oct 13, 2018 4:54 pm
Fo-Banshee wrote:i also have a 2.5tdi with the epic and I have put in the egr blanking plate. Should I also fix open the butterfly plate or remove it or just leave as is? cheers John
jono40 wrote: I have blanket the egr and cable tied the buttery fly open and runs sweet
wojciech
Re: egr blanking
Postby Fo-Banshee » Mon Oct 15, 2018 10:48 pm
Wojciech, by any chance, do you know the purpose of the butterfly?
Fo-Banshee
Re: egr blanking
Postby wojciech » Tue Oct 16, 2018 4:05 pm
Fo-Banshee wrote:Wojciech, by any chance, do you know the purpose of the butterfly?
viewtopic.php?f=31&t=148596
Looking on first picture - butterfly 25(throttle) is mounted in inlet between turbocompressor and EGR 24. Butterfly is controlled together by the same vacu valve 26. If butterfly is closed, EGR is opened (on idle) - and vice-versa (higher engine speed). In this situation, on idle engine takes from EGR far more exhaust gases than without mounted butterfly. Big level of exhaust gases and low level of fresh air (oxygen) reduce emission of NOx (nitrogen oxides). Usually classic diesel works on idle with big air excess, it is causes of high lever emission of NOx. For environmentalists nitrogen oxides are something terrible. But for engine exhaust gases recirculation is the same, as for people to drink own... piddle. :cry: :cry:
Second idea from environmentalists it is system start-stop.
Latest their idea is liquidate whole world diesel engines production. :!:
wojciech
Re: egr blanking
Postby jono40 » Tue Oct 16, 2018 6:57 pm
thank lads so can I leave it lose or cable tie it open :roll: also I putting bosh pump on will my own throttle cable be ok
jono40
Re: egr blanking
Postby wojciech » Tue Oct 16, 2018 7:17 pm
jono40 wrote:t so can I leave it lose or cable tie it open :roll:
My policy (especially about EPIC :lol: ) is: works fine - don't touch it. Leave it alone...
wojciech
Re: egr blanking
Postby jono40 » Tue Oct 16, 2018 7:24 pm
I thought that but don't sound reliable :lol: but I only had the motorhome for about 8 weeks just feels under powered cam belt changed etc but also it had a new epic pump fitted 3000 hours sorry miles ago yes I work on fork trucks :roll: so I think I will get all the parts and put them in a little box with al my other ford bits :shock: :roll:
jono40
Re: egr blanking
Postby Fo-Banshee » Tue Oct 16, 2018 9:47 pm
Thanks for the info. Yes I'm of the same mind mostly, If it works don't touch it",.....unless there's and extra couple of kw's to be had.
Fo-Banshee
