What are these parts called?
Postby Optomisticnick » Mon Sep 24, 2018 10:20 pm
Hi, I’m just looking for a bit of knowledge on what’s what and hopefully the names of some of the parts from my mk3 county, hopefully someone here will know.
Firstly what are the rubber stops above the leaf springs called?
Cheers
Nick.
Optomisticnick
Re: What are these parts called?
Postby loot » Mon Sep 24, 2018 10:52 pm
The rubber stops I've always referred to as bump stops.
The first image is showing the handbrake cable and some of the outer sheath is rubbed through and showing steel brades, as long as the internal brake wire moves freely then I don't see a problem.
The bottom image I believe is showing the load sensing valve which basically changes the rear brake efficiency based on the weight of the van when loaded. Other than that I can't say if it is working or not. :D
Ids map here
loot
Postby Optomisticnick » Mon Sep 24, 2018 11:02 pm
cheers Loot.
does anyone know how to test if it is working?
Optomisticnick
Postby gotgcoalman » Mon Sep 24, 2018 11:02 pm
Bottom pic.
see if it moves with your hand as it's covered in underseal :idea:
Too bloody quiet :shock:
gotgcoalman
Postby Optomisticnick » Mon Sep 24, 2018 11:13 pm
I will do, cheers.
Is this what the small plaque with a graph on in the passenger step is relating to?
Optomisticnick
Postby gotgcoalman » Tue Sep 25, 2018 5:12 pm
Yep :D
gotgcoalman
Postby dumper » Tue Sep 25, 2018 8:04 pm
When my load sencing valve whent on my mk3 it seized on the piston inside and had no brakes on the rear and would lock up the front brakes. the only Real way to test it if it’s working okay is on break rollers you can adjust it to give more brakeing efficiency on the rear
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Optomisticnick » Sun Dec 30, 2018 9:42 pm
Another one for the list, can someone illuminate me as to what this is/does?
https://drive.google.com/open?id=10zip1zl1WCbyRpWA441d8SPng5ym7BXV
Optomisticnick
Postby Chug » Sun Dec 30, 2018 10:30 pm
I'm on a crap monitor but it looks like the fuel bleed nipple on the side of the injection pump.
Chug
Postby Optomisticnick » Mon Dec 31, 2018 12:40 pm
Chuggy wrote:I'm on a crap monitor but it looks like the fuel bleed nipple on the side of the injection pump.
That sounds about right, just used for getting air out of the system?
Optomisticnick
Postby Chug » Mon Dec 31, 2018 3:04 pm
yes its to bleed air from the injection pump , and also where a gauge to check pump pressure is fitted. :D
Chug
Postby Optomisticnick » Mon Jan 21, 2019 6:08 pm
Can someone tell me the name (or even better a link) of the rubber parts that the gearbox crossmember sits on, some kind of ring around the mounting bolt.
Cheers.
Optomisticnick
