Fuel Filter Change Trasit 1995
Postby jonnybgood » Mon Sep 24, 2018 10:37 pm
Hey there.
Im very newbee in mechanics and trying to sort out basic servicing on my own. Im struggling a bit about changing the Fuel filter of my Transit 1995. Cant find any videos or instructions on the internet for this kind of looking filter.
also, does any of you know where the fuse for the fuel pump could be? or what does it look like?
thank you all
jonnybgood
Re: Fuel Filter Change Trasit 1995
Postby gotgcoalman » Mon Sep 24, 2018 11:22 pm
see the thumb wheel with the threaded part sticking out ?
Pic is side ways so it's bottom centre.
If ( and it usually happens) your pic is the right way.
Undo the the black thumb wheel on the left hand side.
remove the old filter.
try to get an efg87 replacement.
fill the new filter before fitting.
jiggle till it clicks under the band and re tighten.
Have a 17mm spanner handy :idea:
Sometime they purge the small amount of air some times they don't.
Fully charged battery helps.
Too bloody quiet :shock:
gotgcoalman
Postby gotgcoalman » Mon Sep 24, 2018 11:33 pm
Just read the bit at the bottom of your post.
Will it not start?
Fuel pump (lift) is manual = no fuse required.
Injector pump (i'm assuming is Bosch) only has a fuel cut off(electrically controlled by the ignition) and is a manual pump.
By manual
Run off the engine turning over
gotgcoalman
