Removing the gear lever from a five-speed gearbox
Postby Kjeles » Fri Sep 28, 2018 10:07 pm
The Haynes manual is a bit unclear regarding the removal of the gear lever from five-speed gearboxes. It states: "... remove the gear lever knob, unscrew the lever and then remove it from underneath the vehicle".
Do I unscrew the three bolts marked on the photo below, then lift the lever and its attachment up, back and then down through the oval hole in the floor?
Will it not be possible to lift it upwards through the floor?
Why remove the knob? There seems to be plenty of room to bring it down through the floor?
Kjeles
Re: Removing the gear lever from a five-speed gearbox
Postby dumper » Fri Sep 28, 2018 10:34 pm
Probably in the Haynes manual they are probably not removing plate and gator in the cab floor and sliding the lever thro the rubber gator I’d leave the knob on and remove the lever with the gator on
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Kjeles » Sat Sep 29, 2018 10:28 am
Thanks for ideas.
Once I unscrewed the three bolts, it became clear that the lever had to come down. The lever is attached to the cup and cannot be lifted up.
Kjeles
