Mk3 Van Negative (Ground) Wire connection
Postby Saukstas » Mon Oct 01, 2018 6:46 am
Hi,
one more question - where it goes?
Am i wright, that it was there, where starter attached to the body?
(Wrong car, but - something like that):
Saukstas
Re: Mk3 Van Negative (Ground) Wire connection
Postby Saukstas » Mon Oct 01, 2018 6:47 am
...and there are two bolts. Does it matter, on which one it goes - one on top, or one on bottom?
Thanks!
Saukstas
Postby dumper » Mon Oct 01, 2018 8:07 am
If you’re asking where to put the main battery earth lead on the starter it can go on any it will even work on the bellhousesing bolts some starter motors have earth nut on the case of the motor .
Ps it also helps if you put down what model and year of van cheers
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Saukstas » Mon Oct 01, 2018 10:56 am
Thanks a lot!!
it's
FORD Transit 2.5 TD 100 L 1994
damn, it's old :D
Saukstas
Postby dumper » Mon Oct 01, 2018 12:02 pm
Not as old as me :D
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Saukstas » Mon Oct 01, 2018 12:39 pm
Well, - same here :D
Saukstas
Postby F111ORY » Mon Oct 01, 2018 8:39 pm
Hi, I just thought to mention that besides the main earth lead from battery to the starter that there is also a smaller earth lead of about 60 amp capacity from the battery to the frame of the vehicle ( usually bolted just behind the headlight). The main leads that run from the battery to the engine ( both positive & negative) are continually flexing as the engine vibrates on its rubbers and often need replacing after 10 to 15 years!
F111ORY
Postby Saukstas » Wed Oct 03, 2018 10:55 am
oh, alright, thanks
Saukstas
Postby Saukstas » Mon Oct 22, 2018 7:50 am
ok, strange....
everything went fine, i've started my van and been driving with it
but after a week or so without use, i can't start it again.
And where positive wire goes to starter, there's kinda smoke (burning), if i turn the key for longer time
any ideas?
Saukstas
Postby dumper » Mon Oct 22, 2018 10:40 am
Loose connections ?
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Saukstas » Mon Oct 22, 2018 10:58 am
i've read some forum threads, so, yeah, i also think that might be it..
Saukstas
Postby vanfox » Mon Oct 22, 2018 12:54 pm
Assuming the securing nut is tight, more than likely the crimp on the cable has failed, not unusual. Chop it off and replace with a new crimp or replace the lead.
vanfox
