How to disconnect the clutch cabel, mk3 petrol?
Postby Kjeles » Sun Oct 07, 2018 2:59 pm
The Haynes manual explaines that the clutch cable can be removed by first "unhook[ing] the inner cable from the toothed segment of the automatic adjustment mechanism on the clutch pedal" with reference to a photo. Sounds and looks simple enough. However, using a pair of pliers, I am not able to lift the end of the cable to free it from the hook.
Any trick to this?
Kjeles
Re: How to disconnect the clutch cabel, mk3 petrol?
Postby gotgcoalman » Sun Oct 07, 2018 3:09 pm
self adjuster.
lift the pedal to disengage the ratchet mechanism from memory.
it allows the toothed segment to be moved back.
Too bloody quiet :shock:
gotgcoalman
Postby Kjeles » Sun Oct 07, 2018 5:07 pm
Thanks. It turned out that the pawl was missing and the toothed segment was held in place by a bolt that was drilled right through the plastic body of the segment. A home repair, apparently.
Kjeles
