Banana engine won't rev
Postby E15mas » Sun Oct 07, 2018 7:11 pm
Hi problems with my 2.5 banana
Started yesterday morning and started fine but as I set off it felt gutless thought it would clear but didn't so changed filter and no better no air bubble coming up the feed pipe has now got worse and will struggle to rev up at all and can get it to about 3000rpm but it will stay there for a few seconds the the revs drop of and it tries to dies even thou foot flat to the floor tried feeding direct to the pump from a jerry can but no differant any ideas guys thnx in advance
E15mas
Re: Banana engine won't rev
Postby dumper » Sun Oct 07, 2018 7:30 pm
Have you done the leak off pipe work mod the return pipe from no4 injector needs re pipeing so it comes off number 1 injector and the bung on the end of the no 1 needs to go on no 4
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby E15mas » Sun Oct 07, 2018 9:29 pm
No I haven’t I shall try that 2moro can that make a difference is it no1 or no4 the injector at the front nearest me
E15mas
Postby gotgcoalman » Sun Oct 07, 2018 11:45 pm
lift pump ?
Too bloody quiet :shock:
gotgcoalman
Postby dumper » Mon Oct 08, 2018 7:14 am
Number one is the front injector if not had mod bung will be on it if not try
gotgcoalman wrote:lift pump ?
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby E15mas » Mon Oct 08, 2018 7:22 am
Will do leak off today and bypassed lift when i tried gravity fed from a can but no help
E15mas
Postby E15mas » Mon Oct 08, 2018 5:10 pm
Went to do leak off and she started and revs fine today which is weird but did leak off mod anyway could it be a sticky torque sleeve
E15mas
Postby Altransit » Mon Oct 08, 2018 7:05 pm
E15mas wrote:could it be a sticky torque sleeve
Yes :|
