Banana engine diesel pump replaced won’t start
Re: Banana engine diesel pump replaced won’t start
Postby dumper » Wed Oct 10, 2018 5:19 pm
When you pinned it up to put the belt on did you slacken the bolts that hold belt sprocket to the pump and tighten it up when belt adjusted if you don’t it can put the pump timeing out by a degree or so
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby flateric » Wed Oct 10, 2018 5:31 pm
All 3 pins straight in :(
flateric
Postby vanfox » Wed Oct 10, 2018 5:55 pm
Pin the motor. Take out the IP pin and replace with a smaller pin/drill, try 5mm. Loosen the four bolts on the pulley and turn the pump hub clockwise. Tighten the four bolts and see if it improves. If it does try a 3mm drill, Sounds like the pump boss may have been out of place.
vanfox
Postby flateric » Wed Oct 10, 2018 7:01 pm
I’ll get back on it tomorrow. At least it tried to start today so that’s something
flateric
Postby flateric » Thu Oct 11, 2018 1:00 pm
It lives. Thanks all for the help. :D
Had to take belt off. It was a full tooth out, still smoked at full adjustment so took it a tooth & used a 5mm drill.
Awesome guys.
flateric
