rebuilder86 wrote:i think the ebay ones would be fine, just replace them again when the seals die. Thats basically the main failure point.
So driving around gently is the quickest way to make these seals perish.
You gotta give it stick off the line, and let off early on the way to lights using the engine as an engine brake.
rebuilder86 wrote:there is one thing ive just realised about my post which is wrong, engine braking, the throttle valve thing that does this is downstream of the turbo, so using the engine as a break probably does nothing to help it. just dont ever stop, go through all red lights is my best advice.
