Mk5 2.5 di starter amps
Postby powercrazymark » Tue Oct 16, 2018 12:29 pm
Hi does anyone on here know how many amps a 2.5di stater motor will draw?
CRAGGS AUTOMOTIVE RECOVERY & TRANSPORT
FULLY INSURED SERVICE, BASED IN TYNE AND WEAR
email:- CRAGGSRECOVERY@GMAIL.COM mobile:- 07506508703
powercrazymark
Re: Mk5 2.5 di starter amps
Postby dumper » Tue Oct 16, 2018 12:41 pm
I think around 150 but a long time since I have checked one with a inductive amp meter so not 100% sure
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Harry_Viderci » Tue Oct 16, 2018 12:57 pm
powercrazymark wrote:Hi does anyone on here know how many amps a 2.5di stater motor will draw?
The ones I have seen are are rated around 2kW, so 2000W ÷ 12v = ~170A. This is a ballpark figure as the battery voltage will drop considerably under load. Why do you need to know?
Sent from my D5803 using Tapatalk
Harry_Viderci
Postby powercrazymark » Tue Oct 16, 2018 1:32 pm
I've got 2 batteries on and am going to fit a webasto heater. But I want to isolate one battery as a backup in case the heater drains the 1st battery. So am trying to get a battery isolator relay so that I can boost to start if needed but not sure what size would be needed.
powercrazymark
Postby dumper » Tue Oct 16, 2018 7:31 pm
I used to use a heavy duty master switch to one of mine I put it in the earth lead
on one van I had it in between the leisure battery and the starter battery
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
