1999 heater control panel lights.
Postby vanfox » Wed Nov 07, 2018 4:13 pm
Any one found a way to replace the two bulbs in the heater panel, the later rotary control one. I can get my fingers to the bulb via the slot under the radio but not a cat in hells chance of turning them.
vanfox
Re: 1999 heater control panel lights.
Postby gotgcoalman » Wed Nov 07, 2018 5:16 pm
Just checked haynes.
step 1. remove engine.
step 2. cut suitable size hole in bulkhead.
step 3. reach in to replace bulbs.
They rate it at 3 spanners :lol:
Too bloody quiet :shock:
gotgcoalman
Postby vanfox » Wed Nov 07, 2018 5:30 pm
Ha, yes. That's also the way to replace a Pinto camshaft without removing the head......but seriously.....
vanfox
Postby wojciech » Fri Nov 09, 2018 7:56 pm
vanfox wrote:but seriously.....
Seriously? Ask for this work pickpocket ... :twisted:
Looking at new bulbs, fit tightly to the bulb holder soft (but strong) plastic pipe of adequate diameter (long about 4-5inch), it can be good tool to do it - to turn bulb and take it out... :idea:
wojciech
Postby MinorMatt » Mon Nov 12, 2018 10:27 am
Undo the screws holding the panel in place and there is enough slack in the cables to move it to a better position.
2 on the outside of the dash, and one in the middle inside the dash
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
