by cherniy_chack » Wed Nov 14, 2018 12:48 pm
You start with the simplest thing: you take off the starter control wire from the starter, instead you plug in another one about 1 meter long.
Turn off the gear on the gearbox, put the car on the parking brake and connect this connected wire to the + battery.
If the starter turns on and works, then the problem is in the relay or wiring.
If the starter is not working, remove and repair the starter.
If the starter works from an additional wire, but does not work from a key, then remove an additional wire, put in place a regular one.
Find the starter relay and its fuse.
You have been told where to look for them.
Check the fuse visually, take it off several times and put it in place.
This will help to clean its installation contacts from dirt.
Try to start the motor from the key.
Do not start-remove the starter relay.
Usually, the narel and the nest have a pinout of the relay for its installation.
I have never shot this relay and I don’t know for sure, but I think it has four pins or two for switching on the relay and two power for connecting the starter.
Find them and in the slot for these pins insert a curved piece of copper wire without insulation with a thickness of about 1 mm.
If the starter turns on, the problem is in the relay. It will need to be replaced.
It may be the case that the maintenance of the relay does not turn on because the anti-theft system blocks its operation or the ignition lock and wiring from the ignition lock are faulty.
In this case, you should contact the experts.
It is difficult for me to explain further actions through Google Translator.
