grinding noise
grinding noise
Postby kennystag » Tue Nov 13, 2018 9:56 am
Hi Chaps,
When I turn the steering wheel on my MK5 tranny there is a terrible gridding noise coming from the front passenger side of my Campervan, I am not sure if it is coming from the top or the bottom of the suspension. Any body help with this one before I strip her down.
Cheers All
Stag
kennystag
Re: griding noise
Postby vanfox » Tue Nov 13, 2018 1:05 pm
Check both the bottom ball joints and quick!!
vanfox
Re: griding noise
Postby dumper » Tue Nov 13, 2018 1:17 pm
Also wheel bearings and springs
Re: griding noise
Postby MinorMatt » Wed Nov 14, 2018 2:50 pm
Loose power steering belt causes bad noises when steering
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: griding noise
Postby gotgcoalman » Wed Nov 14, 2018 10:00 pm
power steering.
It has got fluid in hasn't it?
Too bloody quiet :shock:
gotgcoalman
Re: griding noise
Postby RustWidow » Wed Nov 14, 2018 10:16 pm
gotgcoalman wrote:power steering.
That’s so not funny... :cry:
RustWidow
Re: griding noise
Postby gotgcoalman » Wed Nov 14, 2018 10:21 pm
sometines the simplest things get overlooked.
as said
bottom ball joint is #1 suspect.
track rod ends.
Top turret on shocker.
gotgcoalman
Re: griding noise
Postby bambi mk 1 » Wed Nov 14, 2018 10:34 pm
track rod ends.
Frozen shoulder if there is no power steering
FIFY :wink:
bambi mk 1
Re: grinding noise
Postby gotgcoalman » Wed Nov 21, 2018 8:46 pm
It it a grinding or a loud creaking noise?
I have been afflicted with the screeching creaking today. :lol:
Quick diagnostic and..........
top turret bush is doing the seize up thing :roll:
gotgcoalman
Re: griding noise
Postby Hondekop » Thu Nov 22, 2018 5:19 pm
vanfox wrote:Check both the bottom ball joints and quick!!
You can check them by injecting some oil through the rubber boot and then turn the steering wheel: if the ball joint is rotten, the noise will disappear. If it wasn't the ball joint, you can glue a cycle tyre patch on the hole to reseal it.
Ciao, Kai
1992 MK4 LWB van, 2.5 TD 101 HP
Hondekop
Re: grinding noise
Postby gotgcoalman » Sun Nov 25, 2018 12:27 am
mine was definatly top :(
gotgcoalman
