Lucas EPIC intermittent problem
Postby keranski » Sun Nov 25, 2018 7:51 pm
Hi all. I'm new to the forum (obviously I join the forums when I have problems, blame me :roll: ).
My name is Trayan and I am from Bulgaria.
I have a second gen (1999) Transit 101hp fitted with the EPIC FAIL :D
The pump is going crazy. When I start the engine (starts fine) and I drive, the first minutes the bus is fine, it's full on power, no problem.
After a several minutes it goes in limp home mode and a check engine light appears.
If I restart the engine it goes well again, again a few minutes or second time maybe less and the problem occurs again.
The problem is I live in the god-forgotten land of Bulgaria and nobody wants to deal with a Lucas, nobody has the proper diagnostics and nobody has the knowledge :roll:
I bought the Ford three years ago, it had the problem before, but wasn't a problem for me (restart the engine, drive a few km's, restart and so on...), but now it's time to sell it, because I don't need it anymore. And nobody wants to buy it broken :D
I don't want to spend a fortune on the bus (like fitting a new pump or a bosch pump).
So is there a way that the timing is out and I just need to change the timing belt (I haven't changed it, I don't know the last time it's changed) and is this a way to fix the problem?
Or maybe something else?
Thanks all in advance and best wishes :P
keranski
Re: Lucas EPIC intermittent problem
Postby wojciech » Sun Nov 25, 2018 10:20 pm
viewtopic.php?f=2&t=190300
For your model (Mk5) you need solenoid plunger No. Delphi 9160-562B
Try do it - exchange plunger. It is possible to do by yourself.
Look for MinorMatt posts - this guy is Guru about EPIC. He wrote thread with good pictures how to do this work.
wojciech
Postby Altransit » Sun Nov 25, 2018 11:06 pm
If you haven't changed the belt, then I would do that first :idea:
Postby MinorMatt » Mon Nov 26, 2018 7:21 pm
wojciech wrote:https://fordtransit.org/forum/viewtopic.php?f=2&t=190300
Not the symptoms of ESOS failure.
Either cam ring seizing or cambelt needing to be changed
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby keranski » Mon Nov 26, 2018 10:06 pm
MinorMatt wrote:Not the symptoms of ESOS failure.
What do you mean cam ring seizing?
Thank you a lot.
keranski
Postby cherniy_chack » Wed Nov 28, 2018 5:10 pm
Hello,keranski.
Lucas Epic around the World nobody wants to do.
There are several experts in Ukraine, in Kiev "Avers" and in the Dnieper Sergey.
There is a specialist in Minsk, Belarus and in Moscow, Russia.
cherniy_chack
Postby wojciech » Thu Nov 29, 2018 3:39 pm
keranski wrote:The problem is I live in the god-forgotten land of Bulgaria and nobody wants to deal with a Lucas, nobody has the proper diagnostics and nobody has the knowledge :roll:
It's like that - about EPIC - whole Europe is god-forgotten land, even maybe whole World... :lol:
One more idea - check is it vacu in tank, when poblem is active. :idea:
wojciech
Postby cherniy_chack » Sat Dec 01, 2018 1:42 pm
keranski,Turkey produced Transit Otosan with a mechanical Bosch VE injection pump with a 100 hp turbo-corrector.
I myself have such a fuel pump.
I understand your attitude to the Turks, but no one bothers to look for such a Bosch VE fuel pump in Turkey.
cherniy_chack
Postby cherniy_chack » Sun Dec 02, 2018 7:47 pm
keranski,in Sofia there is a service for the maintenance of Delphi systems.
https://www.delphiautoparts.com/rus/ru/ ... pi_state=1
cherniy_chack
Postby keranski » Sun Dec 09, 2018 5:01 pm
Well, I changed the timing belt. It was not the problem.
The bus seems to be better, no limp mode, no check engine, but still out of power. When stopped and I go with wide open throttle, and in all other wide open throttle situations, the nose dives??? Still very weak on power. Can this be fuel filter related? Or something clogging the fuel sistem? Thanks a lot all.
keranski
Postby keranski » Thu Dec 13, 2018 10:32 pm
Well, changed the fuel filter today.
Nothing.
Any suggestions? I'm really very mad of the ford and I need it gone soon, so I will have to fit the Bosch manual pump I suggest?
Do I have any other variant, any possibility it's not the fuel pump that is causing the problem?
Thanks a lot.
keranski
Postby wojciech » Fri Dec 14, 2018 6:52 pm
What about smoke - is it? Black, white, blue? How it smell?
Check inlet pipes with air filter and manifold, turbo, EGR plus throttle (they are controlled by the same vacuum transducer).
Did you touch start-stop valve with solenoid plunger?
wojciech
Postby keranski » Sun Dec 16, 2018 1:26 am
No smoke at all.I haven't touched the plunger.
In Wednesday I will check all the piping and all the vacuums.
Can somebody explain to me where is the lift pump from the reservoir located and how to check it?
keranski
Postby WvdVate » Wed Dec 19, 2018 8:18 pm
Same problems here. I have a Ford Transit Nugget MK3, 1993, 2.5 TD, with an electronic injection pump (Lucas Epic DSA947). I guess you need a newer one. But before you buy a new one, check the magnetic switch of the pump you have right now.
Nu the wat: if anyone has a spare DSA947 please contact me!
WvdVate
Postby Fastfish » Tue Jan 15, 2019 8:02 pm
WvdVate wrote:Same problems here. I have a Ford Transit Nugget MK3, 1993, 2.5 TD, with an electronic injection pump (Lucas Epic DSA947). I guess you need a newer one. But before you buy a new one, check the magnetic switch of the pump you have right now.
I have a complete spare Epic set up incl the pedal etc, I swopped it out for a Bosche mech one
Fastfish
