Chuggy wrote:Standard 25.4mm belt or turbo with 28mm belt?
part nos
1135358 = 25.4 mm belt kit
1136426 = 28 mm belt kit
https://www.onlinecarparts.co.uk/oenumber/1135358.html
https://www.onlinecarparts.co.uk/oenumber/1136426.html
gotgcoalman wrote:I always get a "branded" one from my local motor factor.
Buy off fleabay and risk getting a "fail soon chineesium copy"
think my last one was a Dayco or Gates.
bambi mk 1 wrote:gotgcoalman wrote:I always get a "branded" one from my local motor factor.
I wouldnt use a Gates Transit belt for holding up my trousers,Dayco all the way
bambi mk 1 wrote: I wouldnt use a Gates Transit belt for holding up my trousers,Dayco all the way
cheap and nasty
Altransit wrote:bambi mk 1 wrote: I wouldnt use a Gates Transit belt for holding up my trousers,Dayco all the way
That's an interesting comment, (because I trust your judgement), as I have a couple of Dayco belts in the garage, that I bought when I had the Mk5. I bought one of each size, because being a July '97 build, I wasn't sure which it had.
When I actually changed the belt, I ended up buying and using a genuine Ford kit because of being told (at the time) that Dayco werecheap and nasty
That not being the case, I'll dig them out and sell them
Chuggy wrote: I'll have a look and if I haven't got one in me spares collection I'll be Interested in the 28mm one Al?
bambi mk 1 wrote:I never use the modified tensioner as I consider the original far more robustGates belts are a no no due to some breaking at less than 15 hundred miles
When you look at the 1.8 d mk 3 Fiesta the belt broke just by looking at them till Ford changed their oe supplier that had a teflon coating on the teeth an guess who the supplier was
Yes you have it in one Dayco
I never had one break at less than 100k
V184 wrote: The very early di had a different belt i think so 3 different ones ? ( no doubt i will be told if wrong)
V184 wrote:The very early di had a different belt i think so 3 different ones ? ( no doubt i will be told if wrong)
