On most transits I know, there is a standard limit of about 105mph 168.981kph I'm not sure about older mk5 like yours though.
If you want to check that limiter or make it go faster then you'll need a remap anyway because I don't believe that ford diagnostics will remove the 100~ limiter only the 60/70mph limiter.
No offence though but I expect doing 160+kph in a standard mk5 must be exciting
I wish you the best and hope you find the answer, there's a few clever chaps about that may help.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
Ids v86 licence + v86.04 update + xprog
hereIds map
here
