Mk 5 190 hi cube... fibreglass roof strength?
Postby Fast but dim » Thu Jan 03, 2019 7:54 pm
I bought this a few months ago:
viewtopic.php?f=7&t=188378
She runs like a dream ( I'm going away tomorrow for a couple nights)...
Does anyone know how strong the roof is? I've drilled it to mount some lights, and it certainly seems robust!
I'm looking to fit a roof box, probably fabricating brackets and using sikkaflex and screws. Loads will be light, but I'd really like to know how strong the roof actually is.
I'd guess it would take my weight, but wouldn't want to risk it!
Fast but dim
Re: Mk 5 190 hi cube... fibreglass roof strength?
Postby ernie b » Thu Jan 03, 2019 8:38 pm
Mount through the steel strengthening ribs if you can if not use a steel spreader plate maybe 6 or 8 inch square. I'd plate inside and out to be safe.
As for how strong in general, I've seen a car sitting on top of one in a scrap yard and no problems, couldn't even find any cracks in the fiberglass when I got it home :roll:
ernie b
Postby Fast but dim » Thu Jan 03, 2019 9:35 pm
Thanks. I'm not going to be able to locate the ribs: it's an ex ambulance and has been insulated and lined.
I'd assumed the roof was just fiberglass: I hadn't expected it to be supported by ribs from the van sides!
I'd guessed it was sturdy: I expected the screws for the lights to self tap into the fiberglass...but no chance.
Fast but dim
Postby Noctule » Fri Jan 04, 2019 1:34 am
Nice purchase!
To find the stiffeners just go out on a frosty morning, as the roof is starting to warm up. You should be able to see the outlines of them in the frost.
This message board thread has some picks that will give you a good idea of where they will be...
https://www.boards.ie/vbulletin/showthread.php?t=2056060300
Oh, and you're missing two of your back wheels too :wink:
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Fast but dim » Fri Jan 04, 2019 11:24 am
Brilliant thanks!
I'm glad it's on single wheels at the back: I've just about managed to buy two winter tyres. I couldn't have afforded four!
Fast but dim
Postby MinorMatt » Wed Jan 09, 2019 1:38 pm
Mount through the steel support ribs. Just use a pipe/cable finder to locate them.
You would want to do that anyway to ensure you don't drill through a cable?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
