Hello,
Trying to get my mk4 (1994) back on the road and almost ready now (passed mot) but there is an issue.
1st gear is hard to engage (worse when engine cold?) and when I pull away engine 'judders'/wants to stall so I have to keep revs up. Does not do this in other gears.
Any thoughts? I'm going to remove and re-grease the gear selector following a post on here and will let you know if that helps.
