Mk 5 transit passenger window replacement
Postby slogger » Tue Jan 22, 2019 4:17 pm
Having no luck getting the glass out of a donor vehicle let alone fitted to my truck ....Done the door card and drilled out the rivets etc but how do you get the glass actually out of the door without cutting the door ..
Is there a vid on here i could look at
slogger
Re: Mk 5 transit passenger window replacement
Postby slogger » Tue Jan 22, 2019 5:05 pm
Sorted ... I bent the door a tad where the window lips in ...INTERNALLY ...Bet there is a better way but for the life of me i could not work it out
slogger
Postby MinorMatt » Wed Jan 23, 2019 3:06 pm
Never had a problem... did you take the runner off?
Winder mech off, the support panel for handle off. Drop glass in to the bottom of the door and then lift out
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Users browsing this forum: estellef
