banannarama wrote:I have the switch out now !!!! When I do a Continuity test on the switch from the live in to the other pins on the switch position one does one pin position 2 does 2 pins and position 3 does no pins the same as the off position ? Thoughts anyone ?
transitjack wrote:brilliant advice from gotgcoalman
i had to swap out my motor 2 weeks ago and you do indeed need to remove the middle fascia panel (2 screws hidden behind the speedo console cover so this needs unfastening first
i had already cut the front of the housing where the motor sat as last time i was in there i failed to get my motor out (the brushes had worn out) but this time i took the two heater pipes out one from the hole in the middlew and one by your left foot if r/h drive
do be sure to see why no electric first though
the motor body turns say 1 inch anti clockwise to free it from the heater housing
i bought s/h off ebay from a breaker as i reckoned a used ford part was better than a chinese copy,its the same as the mk6 according to what i read and it cost £20 delivered very very quickly
