The clutch on a Mk3, petrol, manual shift, acted up yesterday while stuck in stop-and-go rush hour traffic. The clutch has been fine before and after, but in the stop-and-go traffic, the van started shaking (jerking) when releasing the clutch in first gear on a slight uphill. It appeared to be a situation of intermettent slip-and-grip by the clutch -- not an engine problem. The shaking could be avoided, though, by increasing the rpm of the engine a bit when releasing the clutch, whereby the van started moving in a normal manner.
What might this trouble indicate?
Worn clutch plate?
Burnt/glazed flywheel and/or pressure plate?
Worn release mechanism?
Oil on the clutch?
What do you think?
