drivetheglobe wrote:Thanks, in the meantime Nr 7 is removed - so only one broken, will try to remove as you said and then weld a nut on it as its broken outside.
Think it was damaged before as it was broken easily, more easy than the other to get them out.
Have read in my book that they put some paste in - should I and which ?
