m25roundabout wrote:I wonder if you will receive this reply Altransit? And I wonder if you may have an answer to another question which has just popped up? Usually my transit, Clarence, has no problems going up hills but recently the temperature gauge seems to be creeping up. Climbing Dunkery Beacon in Somerset it definitely overheated. The pipe leading straight down from the coolant reservoir does not seem to have a flow of water in it, only air, yet the coolant reservoir is full. I am thinking some sort of airlock. Do you have any thoughts on the matter that you would mind passing on? Many thanks if so. (ps. I let engine cool down and made the extra 100 metres to the top of the hill!). Cheers.
Altransit wrote:Yes, that's the 76ps "Banana" Di engine (Name is derived from the shape of the manifolds on top!) and yes, it's a Bosch pump
m25roundabout wrote:Yikes. Getting a bit more complicated?!
