2.5di banana aux-belt noise.
Postby maartenh » Mon Jul 29, 2019 12:29 pm
Greetings from the Netherlands!
First, thanks for all the information already posted on the forum, it helped me a lot already to keep my smiley face 2.5 di motorhome up and running!
But i have noise from the engine bay which i don't know how to solve, so it was time to finally create an account and post something.
During a holiday trip in Italy, i heard anothe smiley face with the same noise.
Here is a video: https://www.youtube.com/watch?v=dpaVaes ... e=youtu.be
( is the video link working? )
what is already done:
Removed the aux-belt: no noise at all.
high-idle: no noise. (only normal engine noise :wink: )
Alternator rebuild (new bearings), and new vacuum pump: no change, still a lot of "rattle and rumble" . (could it be the wrong combination of vacuum pomp and alternator?)
Visco: No play at all, feels as new.
Visco-pulley-hub on the oil-pump-cover: bearing is not silent, needs replacement in the long term, but not "critical" yet. But could this make such a noise?
Is anyone familiar with changing the visco-hub-pulley-bearing? I think this is the part, but i can't find a how-to or information in the haynes:https://www.ebay.nl/itm/323261355963
Do i need to remove the timing belt, oil pump cover and use a press to replace the bearing?
Thanks!
maartenh
Re: 2.5di banana aux-belt noise.
Postby blizard » Mon Jul 29, 2019 3:58 pm
Hi Maarten,
Welcome.
Hard to say where the rattling noise comes from, looks indeed a bearing, the wheen needs to stay, because it is part of the belt cyclus
I cut the Visco off and put an electric fan on. There was a hack about that at motomobil.com, but cannot find anymore
Transit MK3 1987
Chausson Motorhome
Engine 2.5TD of 2000 (last production year of the DI, I'm told)
Gearbox MT75
blizard
Postby maartenh » Mon Jul 29, 2019 6:02 pm
It is not the bearing of the visco, but the pulley the visco is mounted on. I can't find how to replace it.
What is a "wheen"?
maartenh
Postby V184 » Mon Jul 29, 2019 9:41 pm
maartenh wrote:It is not the bearing of the visco, but the pulley the visco is mounted on. I can't find how to replace it.
What is a "wheen"?
i think you will have to change the cover that incorporates the pulley, does it still make the noise if you dip the clutch ?
V184
Postby maartenh » Tue Jul 30, 2019 10:51 am
Yes, it is not the clutch.
The oil pump cover is a 500 euro part :|
maartenh
Postby maartenh » Wed Aug 07, 2019 2:50 pm
Both the alternator (rotor is loose on the main shaft?!) and the visco-auxbelt-pulley-bearing are making noise.
https://www.youtube.com/watch?v=HRJ_2Qi ... e=youtu.be
Ordered the parts, time to bring out the tools!
I am going to try to press a new bearing in the oil-pump-cover.
maartenh
Postby maartenh » Sat Aug 10, 2019 5:55 pm
Started today, now waiting for parts.
Bearing was easy to remove with a shop-press.
maartenh
Postby blizard » Sat Aug 10, 2019 6:42 pm
Nice job!
I will go the same route, the plate behind that all has a tear jest behind the waterpump.
I am waiting for the plate from Ireland
Transit MK3 1987
Chausson Motorhome
Gearbox MT75
blizard
Postby hetman » Thu Sep 12, 2019 7:36 am
THank you for posting the pictures and videos, Maarten.
Mike
hetman
Postby Wipeout » Wed Oct 26, 2022 10:33 am
maartenh wrote:Started today, now waiting for parts.
Thanks a lot Marten for sharing this pics..
Im having a similar problem but with the viscus fan flange, tis broken and I want to change for a new one...
Was the crankshaft pulley difficult to take out?? Did you change the crankshaft front seal before remounting ?
Thanks a lot for your answers !!
Wipeout
