vanfox wrote:Leave the pressure cap on filler tank. Disconnect the heater hose from the cyl. head. Check head water outlet is clear. Attach pressure/garden hose to cyl head and turn on water. Water should come out of the heater hose, collect in bucket to check for dirt. Reverse connections, hose to heater hose, need a bit of pipe, turn on garden/pressure hose, water should come out of cyl head, again collect in bucket to check for dirt. If no flow suspect heater matrix is properly blocked.
The heater matrix is part of the engine cooling system, is always at engine temp. The heater is air mix by flaps.
00353theking wrote:Disconnect the 2 pipes from the heater matrix assad get a pressure washer and connect it to one of the pipes and put a jublee clamp on it to stop it coming off then turn it on and watch the brown water come out ,
Once it is clear water coming put it back together and there will be red hot heat coming
Sent from my SM-G965F using Tapatalk
