Hi All.
Had a cambelt snap and whilst stripping engine to do that thought I'd thought I'd change the camshaft oil seal as it's leaked for 2yrs! Once I'd taken off cam pulley I (Don't know why but I did) gave the camshaft a pull with my fingers and it moved out 3/4mm! Went back in luckily but leaves me wondering
a)why the thrust plate let's it move so much. Can't inspect thrust plate as it's behind the engine front plate (intermediate plate in manual) and that's not off. Should camshafts move that much?
b) can I change oil seal from the front? manual says to remove engine front plate and remove from rear of plate but I'd rather not have to get gasket or take off more components
c) can oil seal be changed with camshaft in situ?
Many Thanks All
