dumper wrote:Have a look at the injector leak off pipe where it goes round the back of the engine I can’t remember if it goes to the return line to tank filter head or pump
twin wheel camper wrote:dumper wrote:Have a look at the injector leak off pipe where it goes round the back of the engine I can’t remember if it goes to the return line to tank filter head or pump
It goes to the return line, that’s where I would think your leak is coming from![]()
Work your way back from the injector leak pipe(it’s a small rubber pipe 3-4mm (inside) approximately coming from either the front or back injector) and running to the return diesel pipe at the very back of the engine just up above the gearbox, it t,s into the return pipe and is probably split and leaking diesel at the joint.
If the leak off pipes are looking even a little iffy you should just change them they only cost £5-£6 for a meter length of pipe.
gotgcoalman wrote:Just a silly idea.
When you did the head gasket you didn't trap the fuel return pipe and put a hole in it?
I have the same leak!! Any update? XTimelourd wrote:Still unable to locate the source of the leak. Checked back of head, fuel lines and they're all dry.
It's puddling just underneath the injector pump, but that's dry all over. Pipes are all secure with no leakage. I can't fathom where this leak is coming from. The only thing that isn't solid steel is a big, fat bolt on the engine block. (That's somewhat visible as a dark blotch in the most zoomed in picture.)
I have taken pictures of fuel leak locations.
Further notes:
- The fluid in question smells like diesel, but it's not extremely pungent. I'm assuming that's due to the relatively small amount of it. But, it is oily, and still smells like diesel, though faint.
- The clutch cable just snapped today. The clutch engagement arm that the cable attaches to under the vehicle is somewhat free, so I should be able to replace it and drive, but it has been sticking in 1st and 2nd rather badly lately. I'm including this just in case it's relevant.
