by mustnt-grumble » Sun Sep 29, 2019 11:51 pm
flexis look ok but very old so think will replace.
got the calipers back on the disc and pedal seems to have settled down hard at mid stroke. so I guess that is fine.
the wheel is spinning free when the brake gear is off. I mean really free. bearings are about 4000 miles old, so theyve bedded in, and the wheel itself feels A1 perfect on the spin.
When I put the caliper back on, with the pistons "reset", right back, the wheel is still fine and free.
I then press the brake pedal, and the brakes apply: they're working fine - as brakes.
however, from this point forward, the wheels are no longer fully free. they are free enough to turn with one hand, but it's a slight effort, and no longer do they continue to spin free when you give them a shove.
this is clearly because the brake pads are not backing off fully clear of the disc when the brake pedal springs up.
should the wheels spin fully freewhen the brake pedal is released? or is it reasonable to expect a slight bit of touch from the pad? the pads are I think remaining just in contact with the disc, there is zero squeeze there (otherwise I wouldnt be able to move the wheel at all)
whilst Im on about it, what, WHAT, are the leaf springs actually for? I have always wondered that. (I mean the springs that you always get with new pads that clip on to the caliper)
NB I should say, in all of the above waffle, this is spinning the hub with the studs only: the roadwheel is removed.
