by Chug » Fri Oct 04, 2019 8:45 am
The VE pumps need a lot of force to turn so will be hard to turn by hand, but you should be able to get a little movement until it starts hitting the lift on the camplate, put it in a vice and get a socket on the front pulley nut.
If it doesn't turn check that the 10mm shaft locking bolt is not tightened, someone may have locked the shaft.
