1988 county dashboard questions
Postby Luk3jay » Sat Oct 12, 2019 1:24 pm
Hi guys, my transit county has what appears to be a factory fitted tacho dash. I thought it was aftermarket until I noticed the ford stamp on the top left.
It all works as it should, but i would really like to have an rpm dial. It's our possible to swap the dashboard with a 'normal' one? Or did be of this era (pinto engine) not have an rpm indicator?
It looks like the speedo can just unbolt but i don't want to touch anything without getting a bit more info first. I like to know about everything, and I've never seen a dash like this before. It looks like a tacho card goes on behind the speedo but i don't have the key for it.
Thanks in advance! Image
Sent from my ONEPLUS A5000 using Tapatalk
Luk3jay
Re: 1988 county dashboard questions
Postby MinorMatt » Sat Oct 12, 2019 7:56 pm
Could you have made the pics any bigger? :lol:
Yes its a factory fitted tachograph, and yes you would be able to swap it to a normal speedo - but revcounters wern't available in the mk3 but people have fitted car ones (cortina?) That do have the revcounter
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Luk3jay » Wed Oct 16, 2019 4:56 pm
MinorMatt wrote:Could you have made the pics any bigger?
Thanks for your reply! I might just get one of the cheapy bolt on revcounters from ebay...
Do you know anything about these tachographs? Perhaps what type of key i need to get in it?
Luk3jay
Postby Frag » Wed Oct 16, 2019 6:41 pm
Is it a veeder root tachograph ?
I thought that one key fitted every tacho,they were all the same....
Lucas kienzle were also common tachographs.
Search tachograph key
Image stolen from EBay
Frag
Ford Technician
Postby jay » Mon Oct 21, 2019 9:49 pm
A thin screw driver pushed in the slot will open the tacho..i remember doing that for years in my old cargo, also did it in rentals if they had no keys
jay
